SPECIFICATIONS C5+
Resolution :
32 bits / 384 kHz en dual-mono
dsd 512
Internal characteristics :
Dynamic range : 175 dB
Distorsion + noise : -140 dB
Internal processor 32 bit
Frequency bands 32 to 211 kHz
Analogic output :
Class A Polarization
Bandwidth : 10 Hz - 20 kHz +/- 0.1 dB
Dynamic range : 140 dB
Digital inputs :
All inputs accept signals from 44.1 to 192 kHz :
S/PDIF 75 Ohms RCA connector
AES/EBU 110 Ohms XLR connector
Optique Toslink connector
USB type B : PCM and DSD from 44.1 to 384 kHz
Analogic outputs :
Unbalanced 3 V RMS @0dB -47 KOhms – RCA connectors
Balanced 3 V RMS @0 dB - 600 Ohms – XLR connectors
Power supply :
3 toroidal transformers with 7 independent regulation lines
Resolution :
dsd 512
Analogic output :
Digital inputs :
Analogic outputs :
Power supply :
