מונובלוקים שמורים מאוד מחברת הבוטיק של ג'ף ראוולנד.
חזקים מדוייקים מוסיקליים ברמות הגבוהות.
https://www.theabsolutesound.com/articles/jeff-rowland- ... -amplifier
https://skyfiaudio.com/products/jeff-rowland-design-gro ... ifier-pair
Model 201 Specifications
Output Power Continuous RMS
@ 8 ohms – 250 watts
@ 4 ohms – 500 watts
Frequency Response
5 Hz – 70kHz, 3dB
Peak Output Current
> 35 amps
Dynamic Range
117 dba
Load Impedance Range
2 ohms – 16 ohms
THD + Noise
0.1W-500W/4 ohm
<.05%, typically .006 @ 1kHz
CCIF Intermod. Dist.,
19/20kHz <.002%
Damping Factor
@ 1 kHz 1000
Overall Gain
Selectable Internal Jumper,
26 or 32 dB
Input Impedance
40k Ohms
Common Mode Rejection Ratio
>90dB, 20 Hz 20 kHz
Absolute Phase
Non-inverting, Pin 2 Positive
Inputs
1 x Balanced XLR (Unbalanced operation requires an optional XLR to RCA adapter)
Outputs
1 Pair CE-Approved Binding Posts
Power Consumption
Idle – 9 watts
Maximum – 650 watts
Amplifier Weight
13 lbs/6 kg.
Amplifier Dimensions
2.6″ x 8.4″ x 11.5″
מחיר מבוקש - מחירי חו"ל משומש - כ 4000 יורו
https://www.hifishark.com/search?q=jeff+rowland+201
ינון
o547641258
Frequency Response
5 Hz – 70kHz, 3dB
Peak Output Current
> 35 amps
Dynamic Range
117 dba
2 ohms – 16 ohms
THD + Noise
0.1W-500W/4 ohm
19/20kHz <.002%
Damping Factor
@ 1 kHz 1000
Overall Gain
26 or 32 dB
Input Impedance
40k Ohms
>90dB, 20 Hz 20 kHz
Absolute Phase
Inputs
Outputs
Power Consumption
Idle – 9 watts
Maximum – 650 watts
Amplifier Weight
13 lbs/6 kg.
2.6″ x 8.4″ x 11.5″
ינון
o547641258
