Avi Shpaner
מוצר איכותי לחיבור למחשב או מקור usb.
מוריד רצפת הרעש ומסלק דיגיטליות מהסאונד.
הופך מחשב למקור אודיו מכובד.
מחיר אטרקטיבי
The Intona high speed isolator supports USB full speed 12Mbps and high speed 480Mbps and
Specifications
Provides galvanic isolation to the USB bus
Compliant to USB 2.0 Hi-Speed (480 MBit/s)
Backwards compatible to Full Speed and Low Speed
Isolation withstands up to 2.5kVRMS
Advanced ESD protection (15kV IEC Air-gap Discharge)
Works out of the box, no drivers needed
Transparent to host and device: wide compatibility to all operating systems, embedded systems and devices
Works also with hubs and extenders
Supports all USB-specific transfers and modes
No additional round-trip latency
Powered by USB bus, no separate power supply
Ultra-quiet power rail isolation, linear regulation
300mA nominal (500mA max.) output current on isolated side
Connectors: host-side USB-B; device-side USB-A
Status LED for each port showing bus state and speed
Impedance controlled high-speed circuit design
National compliances: FCC, CE, RCM, ICES-003
IP 54 ABS housing
Dimensions: 135 x 90 x 46 mm
Color: white
Made in Germany
INTONA USB 2.0 Hi-Speed Isolator 7054-X
מנקה סיגנל USB של INTONA
דגם INDUSTRIAL
אלכס
0524840374
מחיר אטרקטיבי
Specifications
IP 54 ABS housing
Color: white
Made in Germany
דגם INDUSTRIAL
אלכס
0524840374
