מממ.
M2TECH עומדים להוציא באוגוסט ממיר חדש
FYI
הוא "מעיף" את כל מה שאני מכיר - לפחות מבחינת ה-SPECS וארכיטקטורה
Vaughan 384/32 reference USB DAC
High performance stereo D-to-A converter in a nice brushed aluminum case and grilled front panel, 440 x 80 x 440 mm. Here follow some specifications:
- input sampling frequencies (kHz): 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384
- resolution: up to 32 bits (USB), up to 24 bits (other inputs);
- inputs: USB (B-type female), S/PDIF (2 x RCA and 2 x 75 Ohms BNC, dual AES for 384kHz), AES/EBU (2 x XLR dual AES for 384kHz), Toslink (2 x for dual AES), ST (2 x for dual AES), straight I2S, external master clock ;
- outputs: single-ended on RCA and balanced on XRL, headphone on 6.35mm jack socket;
- supply: 115-230VAC, optional high current lythium battery with battery changer;
- controls and display: standby and select buttons, encoder, dual large matrix display to show locked frequency and selected input.
A technical note: the Vaughan is our reference DAC, more affordable units will descend from it to cover different price ranges. The Vaughan features 8 D/A IC's (4 per channel in mono mode). A digital dithered volume control will allow for using the Vaughan as a preamplifier. The headphone output is made with a discrete components amplifier.
