..התבררו כ-upsampled
גם בקטלוג של HDTracks
Chesky מורידים את האלבומים, ומחליפים אם אפשר בהיי-רז אמיתי.
מי שקנה וחושש שזה לא היי-רז - יכול לפנות להנהלת האתר ולקבל זיכוי..
מקור:
http://www.audiocircle.com/index.php?topic=69814.msg808259#msg808259
Bruce Brown מ-Puget Sound הוא זה שמבצע את כל הטרנספר מ-SACD ל-PCM עבור HDTracks..
זה מסביר בהחלט למה אני לא אוהב חלק מן הדיסקים שם..
איך אמור להתבצע טרנספר זה היי-רז אמיתי?
מקור:
These Verve 96K masters were transferred using a combination of the best new and vintage equipment available. The carefully chosen original analog masters were played back on vintage Studer 820 tape machines. These machines provide the most stable transport for handling these priceless analog tapes. The analog masters were converted to the digital domain using classic DCS 972 and Lavry analog to digital converters and recorded directly onto a SoundBlade Workstation with minimal processing in order to allow the music to be formatted for digital distribution. The shortest signal path and highest quality cabling were used to prevent any signal loss and additional noise from being introduced into the transfer. The entire digital process was driven with the Antelope Audio Atomic Clock, the industry leader in digital clocking technology. It enables the entire digital process to reference the same highly regulated clock master, preventing any loss in the digital signal due to jitter and clock degradation.
