טל': 0547543987
מייל: vek44acm@gmail.com
מחיר: 3250 שקל
מגבר אוזניות:
Suitable for headphones : 8 Ohms to 2 KOhms
Frequency response : -3dB @ 10Hz & 72kHz
Power output (into 8 Ohms) : 560mW per channel
Max output voltage : 3.7V rms into 2kOhms
Voltage gain : +13.5dB
Dimensions (H x W x D): 57 x 121 x 187mm
Made in England
ספק כוח חיצוני (תדי פרדו):
מחיר: 3250 שקל
מגבר אוזניות:
Made in England
The TeddyCap can replace a single Hi-Cap, Hi-Cap2, or a FlatCap in order to power Naim equipment. It can be used to power Naim preamplifiers such as NAC32.5, NAC42.5, NAC62, NAC72, NAC102, NAC82, NAC202, NAC282, Naim integrated amplifiers such as the Supernait, and CD Players such as the CD3.5, CD5, and CD5x. It can also be used to power phono stages, headline, active crossovers and many more.
The TeddyCap is a significant improvement over the HiCap/HiCap2, which is achieved by using a superior design and high quality components to provide the best possible sound quality.
The design is based on the experience gained with the original TeddyCap mk1 and mk2, and provides even better performance.
