soundquest
AVM SA8.2 ו- HEGEL H30 בטופ של מגברי ה- HIGH END לשנת 2017 במגזין theabsolutesound
לינק ל-theabsolutesound
AVM Ovation SA8.2
$14,999
The SA8.2 does have a sonic character—every audio component does. But like some of the best power amplifiers around, that sonic character is exceptionally limited. In fact, almost all of the colorations you’ll hear through this amp will come from the other components. In neutrality and transparency the AVM SA8.2 comes close to delivering the sonic equivalent of the Golden Mean. Its power is rated, with extreme conservatism, at 220 watts into 8 ohms, 450 watts into 4 ohms, and 650 watts into 2 ohms, meaning it can drive any real-world speaker load, including nominal 1-ohm loads. It can also deliver an immense amount of current, delivering up to 60 volts at the speaker terminals, and enough amperage to deal with any current-demanding speaker. An exceptionally neutral and musical product. avm-audio.com
Hegel H30 Reference
$15,000
This Norwegian powerhouse of an amplifier (375Wpc into 8 ohms) combines the brute-force bass control and dynamic impact of a dreadnought design with a midrange and treble refinement that is reminiscent of a single-ended triode amplifier. The midrange, in particular, is highly vivid and present without sounding the least bit pushy or forward, infusing the presentation with a palpability and directness of expression previously unheard in any amplifier near the H30’s price. Perhaps the H30’s outstanding sonics and high value can be traced to Hegel’s SoundEngine technology, in which dynamic crossover distortion is greatly reduced through a patented circuit, coupled with a rigorous transistor-matching protocol. The H30 can be operated in bridged mode for 1000W, but some of the midrange magic disappears and resolution slightly diminishes. A great bargain in high-powered amplifiers. hegel.com
_________________
סאונדקווסט - יבוא ושיווק מערכות אודיו וידאו יוקרתיות
ירמיהו 43 תל אביב > 03-6721808
www.soundquest.co.il
סאונדקווסט בפייסבוק
AVM Ovation SA8.2
$14,999
Hegel H30 Reference
$15,000
_________________
סאונדקווסט בפייסבוק
