נמכרו---כבלים-USB, POWER, INTERCONNECTS, ניאוטק, אוידה
itzik2305
זוג אינטרקונקטים חדשים ללא שימוש כלל, כבל Neotech NEMOI 3220 OCC Copper + מחברי RCA תוצרת RAMM Audio USA.
The modulation cable Neotech NEMOI 3220mixing insulation PTFEand conductors made of pure OCC copper with a rectangular cross section has a particular architecture allowing a strong reduction in the inductance and capacitance effect.
RAMM AUDIO 30891-GT RCA plug Gold plated Tellurium Copper Ø10mm (Set x4)
Ramm AUDIO has equipped this high-end RCA connector with a Gold-plated Tellurium Copper conductor. The body is made of demagnetized Aluminum black anodized.
כבל חשמל OYAIDE TUNAMI (PCOCC-A) באורך 1 מ' עם קונקטורים שוקו מנחושת מצופה רודיום תוצרת SONAR QUEST.
PCOCC-A - This is an ultra pure single crystal copper originally developed by Professor Ohno. It was then further evolved into PCOCC utilizing a single copper grain wire. This design results in an extremely low level of signal disturbance and loss due to the lack of crystalline borders along the signal path. Oyaide has further refined this process with a highly controlled heating and cooling process and improved furnace management to realize a mirror finish. It is now called PCOCC-A and is the epitome of Japanese craftsmanship.
כבל USB Dual מכסף טהור 99.999% עם קונקטורים מוזהבים באורך 0.5 מ', הפרדה בין כבל הנתונים לכח. LAVRI CABLES Hand Made, אם היה מחברה ידועה וודאי היה עולה מאות $
Carefully handmade braided cable consists of 8 cores of AWG28 (0.33mm ⌀) solid silver 5N purity wire.
• Two separated lines – Data & Power; each consists of 4 cores of silver.
• Gold plated USB A & B plugs.
• Gold plated USB A & B pins (solder side as well).
• Separate double shielding via aluminum foil and copper.
• Woven Teflon Litz construction is ideal to deliver RFI and EMI rejection and provides low capacitance.
• 5N silver transmits electrical signals faster and with less distortion than ordinary OFC wires.
• High grade Teflon insulation gives a predominant air dielectric and is regarded as the best insulator for bare cable.
https://www.lavricables.com/cables/ultimate-silver-dual-usb-a-b-interconnect-cable/
מחירים הוגנים ולכן סופיים, נא לכבד.
נמצא במרכז.
  • ramm-audio-30891-gt-rca-plug-gold-plated-tellurium-copper-o10mm-set-x4.jpg
    KB 30 · צפיות: 80
    KB 39.9 · צפיות: 78
    KB 32.6 · צפיות: 85
    KB 32.5 · צפיות: 78
    KB 28.7 · צפיות: 80
