מסך של שרפ
  • פותח הנושא gado
gado
מישהו מכיר מסך של שרפ lc37px5 ?
לצפייה ממרחק 2.7מ המחיר שלו זול יחסית
הנתונים שלו סבירים, השאלה איזה דגמים מקבילים יש מולו.
offirs
gado,יש לך מפרט של המסך הזה,לינק?
gado
מבחנתי יש מולו את 37c3500 של toshiba .
איזה מסך יותר טוב לדעתך ?
תודה על העזרה
* Hi Definition 1080i TV with 6000:1 contrast ratio - best 37" LCD TV!
* Beautiful Piano Black Finish
* World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!
* World-Wide NTSC M, PAL BG/PAL I/Secam BG, DK/ PAL DK TV tuners
* 37" Active Matrix TFT ASV (Advanced Super View) LCD Panel - Sharp proprietary panel with Black TFT low reflection coating.
* Newly Developed Real 16x9 WXGA (1366 x 768) ASV & Black TFT LCD Panel
* Widescreen 16 X 9 Format
* Digital Comb Filter
* PC Input
* 6000:1 contrast ratio provides incredible images whether you're watching dark or bright scenes!
* Built-in NTSC/PAL BG/PAL I/Secam BG, DK/ PAL DK TV tuners enables you to plug your cable TV line right into the TV and start watching.
* AQUOS Liquid Crystal Televisions are very bright, so you can put them anywhere -- even near windows, doors or other light sources and their picture will still be vivid.
* 60,000-Hour Lamp Life
* Sharp's LCD backlight life is long enough to give you viewing pleasure for many years.
* Image Inverter for Custom Installations allows you to invert the image upside-down or "mirror" image if you need to hang it in an unconventional manner.
* Digital audio amplifier with high audio output 10w X 2
* 176º/176º Viewing Angles are so wide you can view AQUOS Liquid Crystal Televisions from anywhere in the room!
* Carry Handle/Table Stand is the ultimate in convenience! Carry it easily from room to room or detach the one-piece stand for wall mounting.
* Brightness: 450 cd/m
* Lamp Life: 60,000 hours
Built-in Connections:
* HDMI Input X 2
* PC Input
* Component Input (Y/Pr/Pb )
* S-Video Input
* Composite (AV) Video Input
* Composite (AV) Video Output
* Power Consumption AC: 65W
* Audio Output: RCA: L/R x 1
* ENERGY STAR® Compliant
* World-wide Dual Voltage 110-240 volts 50-60 hertz
* Dimensions: 920 x 600 x 306 with stand
* Dimensions: 920 x 600 x 116 without stand
* Weight: 29KG (with speakers and table stand)
* 1 year parts and labor Limited Warranty from Sharp
