מה חושב מנכ"ל / בעלים של חברת Cyrus האנגלית בנושא Made in England
רונן
Made in England
27th Oct 2011
It’s odd how geography changes people’s perception so much. When I am travelling overseas on business it is quite common for people I come across to talk about UK hi-fi manufacturers with respectful admiration. The view from abroad is of UK companies making highly desirable products that sound quite superb compared to mass-produced audio. Am I alone in being annoyed by our scandalous press when they paint a picture of pre-war UK manufacturing struggling to compete? It’s just not true.
Cyrus buys almost all its components in the UK and I can report our suppliers are investing in the latest machinery and technologies to compete at the highest level in a global market. For instance our circuit boards come from Nottingham or Northern Ireland and are made to a far higher standard than samples from many overseas manufacturers we have tried. Our partners have a vested interest in helping us make consistently high quality products and work hard to help us maintain repeatable production test measurements compared to the Golden Reference samples in the Cyrus lab.
Our conscious decision to manufacture in the UK is not because it’s geographically round the corner, rather it is because it is the best place in the world to access top quality engineers and therefore leading-edge manufacturing. As wage rates rise in “low cost” economies the superior quality of better made products will become more and more apparent. Ironically in the Far East most consumers aspire to superior European products and are prepared to pay a sizable premium for the quality and status of a UK made product.
Peter Bartlett
ronenperetz
בוקר טוב רונן ,הרמת לי להנחתה
פיטר חושב שכולם מטומטמים, טען עם הרבה רוח וצילצולים שהוא המציא טרנספורט
מבדיקה שלי ושל עוד הרבה שאולי מבינים הרבה יותר ממני, מתגלה CDROM של מחשב שפוצל לשניים
עם מנגנון טעינה של רדיודיסק לרכב כמות התקלות בשמיים,וליכלוכים על סיירוס בכל הפורומים-אתה מוזמן לבדוק, החברה עברה לפני מספר שנים לייצר בסין ובמקום שהמחירים יירדו הם עלו.
רמת הרכיבים ירדה -CD8SE לעומת הDVD7+ שברשותי לדוגמה, כל רמת הבנייה שלהם שככל שעוברות השנים רק
יורדת במקום לעלות.
רק בסוף השבוע האחרון ביקרתי חבר עם סטאפ של סיירוס : מונו איקסים שחובר אליהם פרה של EAR 834P
לאחר זמן מה התייאשתי וחיברנו את הסיירוס 2 ששופץ על ידי לפני מספר חודשים שאין בו היום קבלים אלקטרוליטים בכלל למעט בספק הכח ששם הוחלפו לקבלי SLIT FOIL איכותיים שהוזמנו מאנגליה ,כל היתר -בגדולים MUNDORF
ובקטנים יותר WIMA POLY ובעוד כמה מקומות קבלי COG שאם תגע תקבל כוויה (מהמחיר).
מה אגיד -ישר בהחלפה הרגשתי שמדובר בחיה אחרת לחלוטין, הכח, הבאס המהיר והעמוק (טוב, למרות 70W על הנייר בכל זאת שנאי טורואיד של חצי קילווולט עם 60000UF קיבול -לא כוחות)מה שהדהים היה הפירוט במיד ובגבוהים
וה-LOW LEVEL DETAIL שפשוט הוגבר והגיע קרוב יותר לבמה.
אני חייב לציין שהייתי מאוכזב מכך שהמגברי מונו בלוק שחוברו לEAR 834P שאמורים להיות סטאפ מפורט ביותר
(בעלות מרשימה של 28000 ש"ח - לא לשכוח) לא הצליחו להתמודד עם דזיין של 20 שנה בעל פרה פאסיבי-למרות איכות רכיבים של מגברים יקרים להחריד ברמת הפירוט ,הבמה ,טונליות, צליל תלת מימדי ועוד.
אזי רונן אתה מוזמן לתרגם את דבריי ולשלוח את זה אליו
falou
צריך להבדיל בין מה "אומר" לבין מה "חושב".
אני לא מכיר מוצרים של סיירוס, אבל כשהנחתום מעיד על עיסתו, רצוי לקחת את הדברים בעירבון מוגבל, מה גם שהמיתוג British Hi Fi הוא חזק וברור שיש יצרנים ששואפים מאוד לשמרו.
באודיו, כמו בכל תחום, רצוי לשים את הקשקשת השיווקית בצד. אפשר פשוט להקשיב.
רונן
יורדת במקום לעלות.
ראשית אינני נציג של Cyrus אינני סוחר ואינני בעל עניין בה למעט שיש לי מספר מוצרים של החברה .
שנית , עלי להגיב מפני שתשובתך מכילה מספר אי דיוקים :
1. אינני חשמלאי / אלקטרונאי ולכן לא אתייחס לנתונים הטכניים שהעלית.
2. Cyrus מתגאה בכך שהיא מתכננת ומייצרת ב אנגליה , נקודה !
ראה בעיקר משפט ראשון בקישור :
http://www.cyrusaudio.com/environmental-considerations
All Cyrus models are designed and manufactured in our headquarters in Huntingdon, England
3. בדיקה שתיארת לא בהכרח מתארת את המציאות - אין ספק שקיים וויכוח בנושא סטאפים עקב מורכבותם.
נראה לי בין השורות שקיימת לך דעה קדומה על החברה ...
ראה לדוגמה צילום אחרון של מוצר עדכני שנמכר כיום - ראה בבקשה היכן הוא מיוצר !
4.
לעניין הצליל , אז אני מאד אוהב אותו ואולי אחרים לא
yairf
נשמע לי קצת כמו זעקה נואשת של אדם מיואש. יש מספיק מוצרים מצויינים שמיוצרים באנגליה וזה כבר הפסיק להיות מתכוון בטוח להצלחה מסחרית, כמו שהבחור למד על בשרו.
falou
מה פתאום שמת "נקודה"?
המנכ"ל מתגאה בכך שהוא קונה רק רכיבים איכותיים, מכיוון שניתן להשיג כאלה באנגליה, ולא מסיבות אחרות (נוחות גיאוגרפית, זהות לאומית וכו').
לכך ענה מי שענה, שמבדיקה שערך, זה לא נכון.
תגובה לעניין.
איפה כאן הדעות הקדומות?
נ.ב. למה לי כצרכן אודיו, צריך להיות חשוב היכן המוצר מיוצר?
ronenperetz
לרונן הנואש
לי יש בבית מספר מוצרים של סיירוס: AV5 , smart power,Q-power,dvd7,cyruse 2 upgraded.
החברה מייצרת בסין -נקודה.
היא עדיין טוענת שהיא מייצרת באנגליה-למרות שזה לא נכון.
הבעלים טוען שהוא משתמש ברכיבים מייצור אנגלי-גם זה לא נכון-אני בדקתי את זה ומכיוון שיש לי ידע לגבי רכיבים
אלקטרוניים ואפילו החברה שבה אני מועסק מייצרת בסין אך כל ההנדסה-שאני חלק ממנה היא בארץ.
אולי רק ייצור המעגל המודפס מיוצר באנגליה.
השנאים כבר למעלה מעשור לא מתוצרת אנגלית-בדקתי.
זה שכתוב MADE IN ENGLAND לא אומר שזה באמת מיוצר שם.
ronenperetz
לFALOU
אומנם סיירוס טוענת שהיא משתמשת ברכיבים "איכותיים" -גם זה לא נכון ,מספיק לפתוח היום את אחד ממוצרי החברה
ולראות מה יש בבפנים -אם אינך מבין בזה אני יכול להדריך אותך.
האמן לי -במקרה הזה תמונה באמת שווה 1000 מילים .
לצערי אם רונן יראה את התמונה- הוא יבכה:(
ronenperetz
בנוסף למרות שלא ממש חשוב היכן מיוצר המוצר -חשוב שיהיה מתוכנן נכון ובנוי מרכיבים טובים ואמינים.
לכן אם אתה בעל חברה וטוען שאתה מייצר בעזרת רכיבים איכותיים מתוצרת אנגלית -הם באמת צריכים להיות כאלה ואם לא זאת תרמית.
כל ההנדסה והפיתוח עדיין באנגליה ,ואפילו ייצור הCASEING של מוצרי החברה.
falou
לFALOU
אני לא כתבתי שזה נכון.
כתבתי שזה מה שהמנכ"ל טוען...
רונן
לרונן הנואש
אני לא נואש ,
סה"כ ציטטתי את מי שציטטתי ולא יותר.
מה שחשוב לי הוא הצליל וההנאה לאורך זמן , ואת זה אני מקבל.
יום טוב .
ronenperetz
שמח בשבילך ,אגב כיצד מורכב הסטאפ שלך?
רונן
תוציא את הרמקולים החוצה מעבר לקו של המזנון, זה דופק לך את כל הבמה.
צודק , אבל אשתי מטילה וטו .
dupo
יצא לי לשמוע הגברה של סיירוס, דווקא דגם ישן סיירוס 1 מחובר לפוקאלים צנועים יחסית 714S, אם הסדרות החדשות שלהם מזכירות את הצליל של הדגמים הישנים, אני יכול בקלות להבין ממה הבחור נהנה.
זה נכתב ע"י אחד היצרנים האמרקאים (השם שמור במערכת), המסר ברור למרות הבעיתיות בכתוב.
    KB 71.3 · צפיות: 471
רונן
נשמע מוכר, כל אישה והוטו שלה.
אשתי לא בבית כרגע , גנבתי 10 ס"מ קדימה , השיפור ניכר , שווה לקחת סיכון ולהשאיר את המצב כך,
מקווה שהיא לא תרגיש .........:בורח:
