נדיר בלוחות.
משפר את יעילות החשמל וכתוצאה מכך גם את הסאונד והוידאו.
השיפור בסאונד מיידי ומדהים!!
בנוסף, מטפל בקרינת האלקטרוסמוג בחדר עד גודל 45 מ"ר.
כניסת המכשיר עם Inlet של חברת Furutech.
יציאה בחיבור Schuko של חברת Furutech.
אתר:
https://www.kempelektroniksshop.nl/...roniks-maxiimus-m100-stand-alone-version.html
Stereotimes Most Wanted Component:
http://v2.stereotimes.com/post/mw2016b
In the case of the M100, that component should be your favorite AC conditioner. That's right, the Maxiimus M100 (and P40) are designed specifically around your current AC conditioner. The Maxiimus M100 sole purpose is to make your current AC conditioner more efficient and thus effective. Not replace it. It's hard to believe and maybe harder to accept by most that two AC conditioners are better than one. I too had a very hard time grasping my mind around the idea. I'm just glad I got the chance to audition it and then offer an opinion. All I can say is that my system is much, much cleaner and more delicate and less restrictive today than it was prior to the M100's arrival. It's as if the Maxiimus M100 turned up the overall quiet. High frequencies have more shimmer and sparkle while the low-frequencies are noticeably crispier and cleaner with greater dynamic shadings as well. Most importantly, there's nary a hint that something extra is now in the signal path. It's incredibly transparent. Thank God. (Clement Perry)
A much larger version of the P40, I am nearly at a loss for words in being able to describe what this unit does for the sound of my system. Just plug my Bybee conditioner into it and EVERY aspect of the sound and soundstage is dramatically improved to a degree I had not thought possible. Easily one of the best tweak products I have encountered, no serious system should be without one of these. (Ron Cook)
מחיר רשמי: 3,700 אירו.
מחיר מבוקש: 8,500 ש"ח.
פרטים נוספים בטלפון: 052-2924048
גיא.
the MAXiiMUS improves the efficiency of your electricity. Due to this, your audio/video equipment will sound much better, shortly after it was switched on. Dynamics, attack and resolution will improve significantly.
אתר:
גיא.
