kopelistus
24 קילו.
200 ואט ל 8 אוהם. 270 ואט ל 4 אוהם.
מחפש החלפה על מגבר עם שנאי חזק יותר.
גם הצעות על קדם מגבר איכותי יתקבלו בברכה.
ואפילו אם יש הצעות על רמקולים מעניינים.
מי שירצה לקנות: מחיר בפרטי.
מהפסגות של סוני בשנות ה-90
http://www.thevintageknob.org/sony-TA-N80ES.html
The bandwidth of this Sony TA-N80ES amp is 10 Hz to 10,000 KHz per channel for a total of 20 Hz to 20,000 KHz. This means that the model picks up anywhere from a whisper of a voice to a loud orchestral performance in your music. It has a frequency response of 1 Hz to 200 KHz, which ensures that it picks up every part of the audio experience.It offers quality high-frequency playback, and it does not have a buzzing sound. This stereo Sony TA-N80ES is a 4 ohms, both-channels-driven unit. The amp delivers 270 watts per channel minimum RMS power. This allows you to pair it with speakers in the 200- to 300-watt output range. The Sony stereo TA-N80ES amp also features a minimal, 0.006% total harmonic distortion. This means that the sound quality of this power amplifier is great for any type of music. On the deep bass notes, the amps deliver booming sounds with no vibration. On the high treble notes, you will enjoy crisp and clear audio from these amplifiers.
