Orac Hi-End
עכשיו מבית TELOS AUDIO גם פיוזים אודיופיליים.
להלן אינפורמציה על פי היצרן:
Traditional "audiophile grade" fuses are normally made using different materials for electroplating the surface of the contact area. However, this method directly imposes colorations to the resulting sound.
When replacing fuse, long and tedious duration is required to fully break-in the fuse in order to get the fullest bandwidth. Unfortunately, most of the power consumptions for the equipments out there rarely fully develop the full potential of the fuses.
The key criteria in run-in are signal bandwidth and electrical current. TELOS AUDIO DESIGN pioneered in delivering the industry first technique that combines both high current and 0 – 50 KHz alternating current to run-in fuses. This technique has been applied to German made industrial grade fuses, each fuse that comes out from our factory is run-in using our TELOS QBT run-in machine for 18 hours. Not only that, each fuse will also go through 36 hours of cryogenic treatment to further stabilize the crystal structure of the fuse conductor.
TELOS QBT-18 fuse was born under such promise, to bring the widest bandwidth to your equipments, yet, not changing the true characteristics of the equipments that you so fall in love with.
במלאי, כבלי אינטרקונקט, חשמל, דיגיטלי ורמקולים של החברה.
