SRC•DX USB to Dual-Coax Bridge
אורןןן
נרכש חדש מהמפיץ האירופאי:
MSRP: 365 GBP
Asking 280 Euro
Comes with original packaging.
SRC•DX™ is a revelation for software upscaling: a low RF noise USB to single or dual-coax S/PDIF bridge supporting 705.6/768kHz PCM that's fully compatible with FPGA-based upsamplers and high-end music servers. Eschewing a direct USB-to-DAC interface means the DAC's USB receiver chip is turned off—resulting in less internally generated RF noise. S/PDIF's self-clocking protocol is inherently much simpler than USB and SRC•DX's low power consumption lowers RF noise further still. This helps to elevate the quality of server-based sources so that PGGB, HQPlayer, Roon and other capable software can sound as good as possible.
SRC•DX is USB 2.0 class-compliant for plug-and-play operation with Windows, macOS and Linux—powered by the 5V USB port. A push-button selects standard or high level for signal compatibility with all DACs. Status LEDs indicate single-coax or dual-coax mode of operation. BNC connections ensure reliable transmission of high-speed digital audio.
נמצא בפ"ת
אורן
052-2425891
    KB 43.1 · צפיות: 13
    KB 50.9 · צפיות: 14
אורןןן
עדיין זמין. קסם של גדג'ט. בפרט לבעלי דאקים של Chord.
