Nordost Qv2 + Qk1 -=נמכר=-
Stigmater
למכירה:
QK1 AC ENHANCER
Qv2 AC LINE HARMONIZER
חדש בקופסה!
Qv2 - תקע אמריקאי
Qv2 - תקע אירופאי
Qk1 - תקע אמריקאי
The QVIBE, Qv2 is an AC Line Harmonizer that is designed to enhance the musical performance and picture quality of any audio or video system, delivering readily demonstrable benefits at an incredibly affordable price. It can be used as a “stand alone” product or to complement a full QRT system including QBASE-Mark II, Qx4, Qx2 and Qk1 units. The Qv2 works directly on the AC line, introducing a carefully calculated range of pulsed frequencies, clocked from the original 50 or 60Hz waveform. The result is a drop in noise floor, with a commensurate increase in image depth, dimensionality and presence, significantly increasing the realism of both musical and visual performance.
Like other QRT products, the benefits are cumulative and Qv2s are even more impressive when used en masse. The compact, “plug-top” construction of the Qv2’s mechanically tuned housing allows it to be inserted into any free socket on your system’s AC line – although adding directly to a QBASE-Mark II maximizes the benefits.
Qv2 units are available in either US (NEMA) or EU (Schuko) configurations, and compatible with 50/60Hz 100 – 240V supplies. However, standard adaptors can be used to employ the Qv2 in other markets. The Qv2 is housed in a mechanically tuned carbon fiber and has high quality gold plated connection pins. It is built entirely in the USA and carries a two-year warranty.
• Works directly on the AC line, actively introducing a precise range of pulsed frequencies
• Increases the depth and realism of the musical performance.
• Lower perceived background noise.
• Deeper, more dimensional and more vibrant picture on AV systems.
• Mechanically tuned carbon-fiber body
• Gold-plated NEMA or Schuko connector
QK1 AC ENHANCER
The QKOIL QK1 AC Enhancer uses a load resonating coil (LRC) to generate a passive electronic field that has a beneficial sonic effect on the AC current.
Like the QV2, The QKOIL provides a vital solution to the issues of AC quality and audio/video performance, but unlike the QVIBE, the new QK1 achieves this by using an LRC furnished with Nordost’s patented Micro Mono-Filament technology. Using our MMF technology in a loading application prevents time delay and distortion of the transmitted signal, making the AC current that much closer to the desired “distortionless condition”. The Sensory results: an improvement in the overtones and pacing of the music as well as a greater sharpness, depth and focus of visual qualities.
The QKOIL is the entry level product in the QRT range, a family of modular, non-intrusive innovations that deliver measurable sonic enhancements and provide power in the purist way. Like other QRT products, the benefits are cumulative and QK1s are even more impressive when applied collectively. It can be used as a “stand alone” product or to complement a full QRT system with QBASE-Mark II, QX4, QX2 and especially QV2 units..
The QK1 is housed in a mechanically tuned carbon-fiber body and equipped with either a US (NEMA) or EU (Schuko) connector. It is compatible with voltages from 110V to 240V, and can be used with an AUS or UK adaptor if required. Plug the QKOIL into any spare socket on your system’s AC Line and experience first-hand the surprising yet indisputable effect it will have on you’re A/V components.
• Generates a passive electronic field
• Allows for greater musicality and improves tonal balance
• Increases clarity of imaging, including sharpness, depth and focus
• Lowers the noise floor
• Load resonating coil using patented Micro Mono-Filament technology
טל: 052-6755215
    KB 46.4 · צפיות: 2,016
    KB 64.7 · צפיות: 2,712
    KB 25.6 · צפיות: 605
    KB 35.5 · צפיות: 1,957
    KB 20.4 · צפיות: 1,991
גיא
מחירים?
Stigmater
Stigmater
נשארו רק אמריקאים
