למכירה הדאק האגדי של Stahl-Tek
30 קילו של איכות ללא פשרות בתוך שאסי מאבן גרניט
קלאס A׳ אמיתי לקבלת צליל חם ואנלוגי,
שימוש בצ׳יפים של 1704K R2R שמשתמשים גם חברות כמו CH Precision.
מחיר ריטייל 25,000$
This dac makes all the other PCM dacs look and perform like kitten
Red book pcm never heard so fabulous. Put dCS in shame
It does not have DSD but can be combined with computers that convert DSD to PCM, or use the mighty Aurender N10 (with DSD conversion) and the DSD performance is there.
The retail price was 25.000 euros, but puts in shame current dCS, Ch precision, Trinity, MSB Select and others. Verified.
It contains the 1704K R2R dac chips like Ch precision, Trinity, etc but it is also powered by a 20 kilos superbly made analogue stages, that the comoetition lacks.
Features
Individual/Fully Isolated Digital Inputs Circuitry Stage.
Ultra-low jitter performance is achieved with the combination of the low-jitter input receiver circuit
and a custom mechanically-damped/shielded Sample-Rate-Converter Module that is governed by a low noise precision master clock circuit.
Supports 24-Bit resolution with Input Sampling Rates from 32kHz to 192kHz, which is automatically Up-sampled to 192kHz.
Dual, Multi-channel, 24-bit Multi-bit segment/delta-sigma hybrid DACs configured for Symmetrically Balanced Two Channel Audio outputs.
Four custom analog filter stages with no non-linear components in the signal path, designed to optimize phase linearity through-out the entire audio spectrum, which is crucial to minimizing audible distortions and sonic degradation to spatial depth and imaging.
Four Discrete Hybrid Bipolar/Mosfet High-Power Class A Output Stage Amplifiers optimized for two-channel balanced mode operations capable of driving low impedance loads.
Oversized Transformers, Multiple Large Filtering Capacitors, and Multi-Staged Regulated Power Supplies for each Digital/Analog Sub-Circuits.
