עדשות חדשות של ניקון - 16-35mm F.4 וגם 24mm F1.4
NIKON הכריזה על שתי עדשות חדשות עבור מצלמות DSLR, שתיהן עבור Full Frame
AF-S NIKKOR 16-35mm f/4G ED VR
Price: $1259.95
Available in late February 2010
Ultra wide-angle zoom lens that covers focal lengths from 16mm to 35mm
Vibration Reduction (VR II) enables sharper pictures while shooting at shutter speeds up to four stops* slower than would otherwise be possible
*As determined in Nikon performance tests.
The adoption of Nano Crystal Coat effectively reduces ghost and flare
An ultra wide-angle zoom lens that, while offering a wide angle view of 107°, is compatible with 77mm screw-on filters
Fixed maximum aperture of f/4
ED glass and aspherical lens elements are utilized for a new optical design that achieves high resolution
Quiet focusing with built-in Silent Wave Motor (SWM)
Two focus modes selectable – M/A and M
Focal length 16-35mm
Maximum aperture f/4
Minimum aperture f/22
Lens construction 17 elements in 12 groups (with two ED glass and three aspherical lens elements, and Nano Crystal Coat)
Angle of view 107° – 60° (83° – 44° with Nikon DX format)
Closest focusing distance 0.29 m (1.0 ft.) at a focal length of 16mm or 35mm, 0.28 m (0.9 ft.) at a focal length between 20mm and 28mm
Maximum reproduction ratio 0.25x
No. of diaphragm blades 9 (rounded)
Filter/attachment size 77mm
Diameter x length
(extension from the camera’s lens-mount flange) Approximately 82.5 x 125 mm
Weight Approximately 680 g/24.0 oz.
Supplied accessories 77mm Snap-on Front Lens Cap LC-77, Rear Lens Cap LF-1, Bayonet Hood HB-23, Flexible Lens Pouch CL-11
עדשה נוספת
AF-S NIKKOR 24mm f/1.4G ED
Price: $2199.95
Available in late March 2010
A fast, wide-angle lens with a fixed focal length of 24mm at the maximum aperture of f/1.4
Fast lens with a maximum aperture of f/1.4 that allows users to capture images with beautiful blur characteristics
ED glass and aspherical lens elements are utilized for a new optical design that achieves high resolution and good balance in terms of aberration for pleasing blur characteristics
Focal length 24mm
Maximum aperture f/1.4
Minimum aperture f/16
Lens construction 12 elements in 10 groups (with two ED glass and two aspherical lens elements, and Nano Crystal Coat)
Angle of view 84° (61° with Nikon DX format)
Closest focusing distance 0.25 m/0.82 ft.
Maximum reproduction ratio 0.18x
Diameter x length (extension from the camera’s lens-mount flange) Approximately 83 x 88.5 mm
Weight Approximately 620 g/21.9 oz.
Supplied accessories 77mm Snap-on Front Lens Cap LC-77, Rear Lens Cap LF-1, Bayonet Hood HB-51, Flexible Lens Pouch CL-1118
נראה שמדובר בשתי עדשות איכותיות וכדרכה של ניקון, גם יקרות למדי...
    KB 13.2 · צפיות: 438
    KB 12.7 · צפיות: 453
איתי_הגיתי
מזל טוב לניקוניסטים.
ה 16-35 עם צמצם 4 בלבד לכזה גודל ומשקל?...הגזימו.
היא כבדה יותר מהקנון המקבילה בעלת צמצם 2.8.
אני בטוח שהאיכות האופטית תהיה גבוהה מאד.
לפי תמונות ראשונות נראה אכן שמדובר על תוצאה אופטית משובחת.
רק לך תסחב עם עדשות כאלו... גדול עלי.
איתי_הגיתי
כן, זה עונש.
ה 2200$ ל 24 מ"מ זה מזה היסחפות.
כמו באודיו היי-אנד.
