מגבר אוזניות החדש של Auris - "אושר מושלם"
or-audio
שמו : Nirvana או "אושר מושלם"
.Nirvana, as it's name suggests, is designed to take you to the state of absolute blessedness – nirvana"
We decided to make amplifier that, besides premium quality and sound neutrality, will enable the user to choose any headphones he likes. With output power of 6.5W pure class A, this amplifier can drive almost any known headphones brand
Nirvana" is based on EL34 tubes in single ended configuration. Drive tube is ECC82"
Impedance choosing is standard in our headphones amplifiers and VU meter shows real output power
Reasonable and affordable price is what Auris always has in mind, because our goal is to enable as many as possible audiophiles to have the chance to enjoy in top quality sound
, Milomir Trosic
Auris Audio
Nirvana Specifications
Tubes 1 x ECC82, 2 x EL34
Amplifier Configuration Single Ended
Input Sensitivity 1.4V
Power output: max 6.5W
Output Impedance 32 Ohm/80 Ohm/150 Ohm/300 Ohm & 600 Ohm
Analog Inputs 3 x Line
Dimensions (WxDxH) mm 300x390x190
Weight (kg) 11.8
לצפיה בסרטון עם ה-Nirvana במינכן השנה
https://www.or-audio.co.il/munich-high-end-2018
0528833339
www.or-audio.co.il
    KB 876.6 · צפיות: 697
    KB 398 · צפיות: 300
