yuvalg9
The Systems Integration Sourcebook.
חוברת של 207 דפים, עם מאמרים מעניינים ביותר על טכנולוגיות, אמולטורים של מסופים, מיקרו-מחשבים, VAX, אמצעי אחסנה (תחילת עידן הדיסקים הקשיחים Winchester), מאמרים לדוגמה: Distributed Modular Networks Eliminate Front-End Bottleneck,32-Bit Co-Processor Boosts Performance In Real-Time Applications,Reducing AP Overhead Optimizes Performance For Signal Processing,General Purpose Bus Eases Interaction Of Distributed Resources,Cache Memory Improves The Performance Of VMEbus-Based Systems,Multibus System Blends Open Architecture With Fault-Tolerant Design,Disk Memory Systems: Plated Thin-Film Media Allows Higher Densities Than Iron Oxide Coatings,Diverging Interface Standards For 5 1/4-In.Winchesters Need New Design Approaches,SCSI Lets PC Systems Maintain Compatibility Of Customized Designs,Computer Graphics,CAD/CAM & Image Processing: Solids Modeling Finds Uses In Both Mechanical And Electronic Design,Data Input & Display Technologies,Lan Bridges Make Network Communications Transparent To The User,LC Plan More Than One Product Generation At a Time, Sevo Technology Raises Capacity Of Flexible Disk Drive Systems 1/2-In.Tape Cartridges Provide More Capacity For Disk Drive Backup, Simple Coding Process Achieves Multi-Track Tape Error Correction,Peripheral Controllersisk Controller Speeds Must Keep Pace With Expanding System Needs, Data Input & Dislay Technologies: Modular VDT Design Allows Terminals With Multiple Configurations,LCDs Compete With CRTs In Many Applications, Printers & Plotters: Herz Binary Ink Jet Technologies Challenges Film-Based Printing, DOT Matrix Printers Vary Greatly In Print Quality And Method Of Operation,Laser Systems Provide High Speed Output For Office And DP Printing,Data Communications: Today's Multiplexers,Modems Are Smaller,Smarter & Lower Priced, Hardware Security For Software Benefits Both Publishers and Users,Mux Design Changes Favor Programmed I/O Over DMA, Power System Technologies: Series-Hybrid Circuits Protect Sensitive Loads From Power Anomalies,Careful Planning Can Avoid Hidden Costs Of Choosing The Right UPS,Ferroresonant Devices Protect Computer Systems.
מגזין נדיר! עם שפע מידע על תקופת הווינטג' של המיחשוב כפי שמפורט לעיל. מבקש 80 ש"ח בלבד. נייד 053-8555536, איסוף מהרצליה או בתוספת 15 ש"ח בדואר רשום. יובל
