חדש בתצוגה! שדרוג לכל ממיר hiFace Evo Two>> M2tech >>
soundquest
חדש בתצוגה
שדרוג לכל ממיר! hiFace Evo Two M2tech
הסדרה כוללת:
ממיר USB/SPDIF ברמה גבוהה,שעון (Master Clock generator) ויחידת ספק כוח ULTRA-LOW-NOISE COMPONENTS לשלושה מכשירים (למשל כרטיס Sotm)
The hiFace Evo Two is a true Swiss Knife for its extreme versatility. Its USB device interface is USB 2.0 Audio Class compliant and supports ASIO under Windows and Integer Mode under OSX. It is supported natively under OSX and Linux.
It can be powered by the USB bus or by an external power supply like the Evo Supply Two.
Its comprehensive outputs set includes S/PDIF, AES/EBU, Toslink�, and I2S in PS Audio standard.
Supported formats include PCM up to 384kHz (on I2S only, up to 192kHz on all other outputs) and DSD up to 256x (on I2S only).
The external clock input accepts word clocks as well as master clocks, even asynchronous to the selected sampling rate. Sampling frequency information are sent out by an optical transmitter to the clock generator for automatic clock switching.
An auxiliary S/PDIF input allows for sending digital audio data to the computer for recording, as well as for sampling rate conversion through the internal SRC.
A cute LCD display shows all settings, together with the selected sampling frequency.
All settings, as well as HID features, are set by a remote control.
    KB 77.4 · צפיות: 460
    KB 73.1 · צפיות: 485
    KB 103 · צפיות: 387
    KB 66.5 · צפיות: 343
    KB 66.5 · צפיות: 469
    KB 18.5 · צפיות: 475
