ככל הנראה בדגם ה SE יש "כתר" על הטוויטרים ( מתוך what hifi ):
Revised and revitalised
Hence this package, the revised and revitalised KHT3005SE. As you’d expect, it retains many elements of the outgoing ’3005. Each speaker cabinet is precisely the same size, finished in exactly the same high gloss black or silver, and available with the same optional floor stands (£125 per pair).
In fact, at first glance, you’d be hard-pushed to tell any differences between the old and new systems. Since many of the revisions to the new set-up are internal that’s no surprise, but look closer, and you’ll spot the ’3005SE sports a ‘crown-horn’ optimiser over its tweeters, which helps smooth response and deliver greater sensitivity at very high frequencies.
Best make sure you get the grilles off and have a good look before you buy, eh.
